Bottom line is that shutting off CDMA has zero effect on your ability to make calls with Verizon to any other person, unless of course YOUR cell phone isn’t VoLTE capable. In which case you wouldn’t be able to call anyone after December 31, 2019
Nope...but it's a free call if he does...Verizon cellphone to verizon cellphone doesnt count against plan minutesRegardless, the call recipient doesn’t need to have VoLTE in order for the caller to initiate a VoLTE call
Not 100% true..3g connects directly to the landline network..via the cell phone tower..4g doesnt .howevere. the land line network is also being switched to VoIP in fios areas..they share the same VoIP network that voLTE 4g usesLandlines and wireless are two different things. voLTE can't communicate directly with landlines, it goes thru a router/switch/converter. An interoperability system is not completely in place for wireless to wireless using voLTE. Verizon and AT&T have a working interoperability in place and T-Mobile says they're working on it but it's not in place yet. Sprint, however, is way behind the 8-ball. Their latest release promises full voLTE sometime this Fall but doesn't mention any interoperability agreement.
At least my LG G3 with Android 6 is voLTE enabled.
It does if you have a 3g phoneBottom line is that shutting off CDMA has zero effect on your ability to make calls with Verizon to any other person, unless of course YOUR cell phone isn’t VoLTE capable. In which case you wouldn’t be able to call anyone after December 31, 2019
Well I guess if you're going to continue to ignore the facts there's no point in going on. Interoperability is required and it is only currently in place between Verizon and AT&T, no one else, period. All your responses assume a dropback to another technology if Verizon voLTE can't connect except Verizon is turning off that 3G technology, there's nothing to fall back on, it's 4G (voLTE) or nothing. Continue to say it will work anyway if you want but it won't make it true. I'm outta here.Bottom line is that shutting off CDMA has zero effect on your ability to make calls with Verizon to any other person, unless of course YOUR cell phone isn’t VoLTE capable. In which case you wouldn’t be able to call anyone after December 31, 2019
The VoIP networks interfaces with POTS..they can connect that wayWell I guess if you're going to continue to ignore the facts there's no point in going on. Interoperability is required and it is only currently in place between Verizon and AT&T, no one else, period. All your responses assume a dropback to another technology if Verizon voLTE can't connect except Verizon is turning off that 3G technology, there's nothing to fall back on, it's 4G (voLTE) or nothing. Continue to say it will work anyway if you want but it won't make it true. I'm outta here.
Sent from my SM-G950U using the SatelliteGuys app!
Limited time offer
