Acquiring signal fluke | Page 2 | SatelliteGuys.US
The guide will not load without signal.
The guide information is nearly a static screen that is loaded into the receiver's memory. It contains only a fraction of the bits of information that even an SD picture requires, and the guide is not an active data stream except at download. Download happens when the receiver is turned off--unless you never turn it off and then you get to wait for it.
I'm not going to read your garbage... it's digital with FEC. Rock on! Perfect picture whether you have a 20 or an 80 on the meter.
You might want to start reading some of the science behind digital systems.
"Represented graphically, the general error-performance characteristics of most digital communication systems have a waterfall-shaped appearance. System performance improves as the signal-to-noise ratio increases."
Graph
http://www.aero.org/publications/crosslink/winter2002/images/04_side1_02.gif
Link
How Forward Error-Correcting Codes Work
These links might help you understand MPEG and FEC:
MPEG-2 video compression
MPEG-2 Video
I posted this issue in another thread before this one was even started. I saw this issue months ago and have to do a reboot when it starts doing that. This is one of the biggest bugs I have seen with the 722.
Why Doesn't Dish Have Real On Demand?
Model 1000 receiver question
