I think the + 12 v connector is for the use of a 12 V switch , use to set on or of in the setup menu .
Better start with the +6 V for the optical sensor .
No the 6v is for the polarotor and is only there when a polarity change is needed,there is another 12v terminal on the bottom row for a switch.I think the + 12 v connector is for the use of a 12 V switch , use to set on or of in the setup menu .
The 12v on the top row is for an optical or hall effect,now whether the optical sensor in his actuator can take the 12v is another matter,but I think it can probably take it.
You have a reed switch,an optical sensor does not use magnets.I presume the Green wire to the receiver runs the 7V? the Black would go to Sensor Return? The Sensor connections on the Supra are: Ground, 12+ DC Sensor Power, Sensor Return, and Ground. I did use an extra wire for ground on the Maspro as I have three wires connected, but I guess that is not needed. It is different than I remember, but it has been a couple decades since I took it apart. It is the optical magnetic wheel. I remembered replacing that with one I bought from USS in the early 90s to give me more clicks for KU. I think I will use the Supra, as I have the original manual for that.
Thanks again for your help.
Well take a pic of that and we'll take a look.The Reed Switch in the other motor doesn't seem to have the wheel though.
That's the wheel and those are the magnets,it's just different from the other one.There is a plastic wheel with metal pieces around the wheel View attachment 135910
I'm pretty sure no,I believe they used a non volatile memory for the settings.Is there a memory battery in the Supra
Limited time offer
