Adding Banner to Sig. | SatelliteGuys.US
Not open for further replies.
thiggin2
1,632
5
TampaBay Florida
Can someone help me with adding a banner to my Sig.
This is what the line I'm trying to add to my sig. but most of the time all I get is a red x.
url]
The link is a good one but sometime the banner will work but most of the time its only a red x.
Thanks.
Note: I added spaces to show you what I use I dont have spaces when I added it to my sig.
onsiteSat said:
no luck I Get a forbidden message
I dont understand it, if you click on the link that shows up you get a dead link but if you hit refresh or go the link is good.
I get the following message
You are not authorized to view this page
You might not have permission to view this directory or page using the credentials you supplied.
Did you click the refresh when you got that message??
Yup they only allow you to see the graphic if the refering page was from the same website, thats why clicking refresh works.
Its a problem with your ISP, and chances are they are not going to fix it for you since they set it up that way on purpose
If you have a .htaccess file in your directories you may be able to turn this hotlinking off. :D
Hmmmm but what is strange is when I submit a post my banner will show up but if I just hit refresh the banner is not there just a red x.
I do have that file. How can I try and turn if off?
Download it and save it as htaccess.txt then open it up. :D
Once I give you the changes upload htaccess.txt then rename it to .htaccess
Damn I wish it was that easy :(
When I try to download it, it keeps saying access denied or permission denied.
It must be owned by ROOT then (Root is the person operating the server) you need them to change it, and I doubt they will. :(
What's It Take? (Some Interesting Stats)
Search Index Rebuild in Progress
