Aiming Ku BUD | SatelliteGuys.US
Aiming Ku BUD
jjstaus
12
East Texas
I,ve just added a Norsat 4508a LNB to my C band dish(10' Mesh) and am getting ready to Tune up the BUD to recieve Ku. Question: I have a DSR920 (no Coolsat yet - I want to make sure Ku is possible) Any reccommendations on which Sat to start with. I think X4 is a good choice, as it is directly overhead. It has HBO, that I subscribe to on C band, but it's all digital. Are there any Ku sats that have analog in the clear Ntsb type signals to look for??? I belive that the analogs would be easier to find. p.s. - I can fit a 3/32 drill thru the BUD's mesh.
There is a test card on AMC -2 tp 6 , but with the 920 You will have to be on
tp 7 to view it, if my memory serves me well , I will have to check and see to be sure
Analog feed on AMC 2 is now on Tr 24. 12180 MHz Horizontal polarity
W-2??
Where is (AMC) W-2??? I don`t see it on my satellite chart nor my 922 listing of satellites.
AMC-2 is at 85.0 degrees, I use generic satelite KA on 4DTV, the analog
channel is tr. 25 using the generic sat KA.
Thanks for the info on this satellite and how to enter it into my 922. Can you tell me if the ploarity is normal or reversed???
4dtv and 31" KU Dish
Question about wind and digital KU signal
