I was all jazzed up to buy the 811 then happened to check out the datasheet. There is no coax output to a TV? I only see RCA/phono type connector for baseband video and audio, component on RCA, the DVI connector and the mini-DIN for s-video.
Does the 811 always upsample or can you use it with a regular interlaced TV? If so, what is the cheapest way to generate a signal with video and audio I can send over a single coax cable to a second "cable ready" TV in another room? Don't think my VCR can take baseband in and generate RF out. I am not going to run baseband plus audio cables all over the house. The two TV's are about 120 feet of cable apart (one TV on the first floor, other on the second floor at opposite end of house) and I already have a single coax snaked through the walls for the existing cable TV that I want to dump.
Ideas? I don't want to hassle with a second receiver box and the extra $5/month. But, the 811 is SWEET and I really want it! My area doesn't offer locals so running an OTA antenna to the 811 is what I plan to do. The HD option is attractive as well, for my Barco projector which I use just for movies at night. The 811 seems to have everything I need except for the coax output.
Thx,
Keith.
Thx,
Keith.
