AMC 7 137.0°W -Anchorage Networks | SatelliteGuys.US
gmd63
205
Got the C-Band up finally, and am checking out the Satellites.
On AMC 7 137.0°W is it possible to get the Anchorage Networks on this bird, or are they a spot beam to Alaska? I can't seem to get NASA either, which Lyngsat & SatBeams says are there.
I just get a couple of ad channels and a "North" channel at 3760mhz
The Anchorage channels are scrambled with COMPEL encryption so most receivers wont scan them in on a scan. If they are in the clear they show up on a scan (which they are not...theyre scrambled)
The 3 stations you got on that TP are GCI Channel 1 (has ads, some programming and Jewelry TV), 360North and a 2nd station that usually says "GCI"
The Anchorage nets are for the cable companies up there
No Channels on 920
First time BUD setup with no true south sat
