AMIKO - amiko mini hd se | SatelliteGuys.US
AMIKO amiko mini hd se
I have plenty of firmware backups, but never made a detailed one for this box. Plus things change so much and I have not used mine lately.
When fred555 comes along, I am sure he will have one.
Reactions: fred555
I think it should be small enough to zip up and post here. If not throw it up on a google cloud or something where you can share a folder and post a link to it, or PM the OP with the link. :)
Reactions: fred555
Fred is that a full backup or just the sat list?
If fred555 made that backup on a different version of firmware than you, that is why you are getting that error. There were many firmware versions for that receiver.
qwertio12 what firmware version do you have on that receiver?
Refresh my memory but yrs ago T134 at fridge was a NA dealer for these and something was done where other Amiko Mini HD FW,Sat list etc could not be used on a unit not bought from and vice versa..I am not 100% on this nor am I assuming qurtio12 has 1 or the other I am just bringing this up incase it could be a problem and would like clarification my self.
Fred did yours come from T134 ?.
What FW version qurtio and did yours come from T134?
Reactions: fred555
I bought all mine from some righteous dude name Micheal, KE4EST
My backup was probably the latest software version maybe, if not then close to it.
I really, probably, shoulda put a readme file in the directory with the backups.
Let me know I can be on standby to hook one up to a tv tonight and get some real information and so forth.
qwertio12 try this one.
Make sure to do a full restore all software + bootloader.
Then go back after it updates and resets and do channel list only restore. If you have the wrong channel list.
Reactions: fred555
I'll send you a PM.
Maybe this one will work qwertio and if it does it is a sat list I built..Not alot of saved channels other than where news feeds can be found and the mux on 97w cband..Now I have this box connected to a 16x1 Diseqc switch and 8 multiswitches so if the file works for ya then the switching to your system is all that is needed.
load it as ALL SW + Bootloader..Let us know if it works.
Reactions: fred555
OTHER Generic receiver set-up
OTHER 16apsk, 32apsk
