Sure, that's the function of the LNA part of it all. Low Noise AMPLIFIER.Hello members,
is it possible to amplify the signal passing through the waveguide of the Dish
Mvg
Put an lnb at the end of it. Use your "wave pipe" in place of the round wave GUIDE.From a copper pipe I made a wave pipe for the dish to experiment with. Now I want to amplify that signal. How?!
I have already done that, and I have a picture. But can that signal still be amplified in that pipe ?!Put an lnb at the end of it. Use your "wave pipe" in place of the round wave GUIDE.
You could always use a HOTTER LNB, as they do exist. If say your present one is rated at 35k noise degrees & 60dB, find one that's 15k degrees, and 70dB for instance.Okay
Shame.
new idea, new opportunities
My intention was to make a double reflection with a (2nd) Sub-reflector of a Gregorian antenna like the one in the picture, but that didn't work for me.You could always use a HOTTER LNB, as they do exist. If say your present one is rated at 35k noise degrees & 60dB, find one that's 15k degrees, and 70dB for instance.
Reliable satellite reception is difficult enough without trying to complicate it with a water feature approach.I'm not talking about a bad signal either, but want to use several small dishes.
Johan is in Holland. I seriously doubt that OTARD counts there!Unless OTARD is in play wouldn't the logical choice be to go for a larger dish rather than trying to boost a poor signal?
The application of reasoning will never overcome Physics.
Nonetheless, OTARD is the only reason I can think of to use undersized dishes.Johan is in Holland. I seriously doubt that OTARD counts there!![]()
Do you consider that a "small dish"?
- The diameter of the antenna is not more than 2 m
NahDo you consider that a "small dish"?
Limited time offer
