Pepper said:I got my 160GB drives (Maxtor 4R160L0) today. One is DOAthe other is fine.
I put the working drive in my 522, with no idea if there was anything already there or not. It apparently doesn't care about blank drives, it went ahead and did its thing, when done I had a working system, with the following issues:
1. No timers. Apparently those are stored on the hard drive.
2. 100 hours available. Apparently it doesn't care about the actual size of the drive, and creates the data partition as 100 hours regardless.
My next experiment is to use Norton Ghost to clone an existing drive, and try to force the data partition to use the entire extra 40GB.
Note: all timers and recordings were intact when I put the original drive back in place.
At this point I have extended the power and IDE cables outside the case. I used a standard IDE flat cable (the ATA-133 type with twice as many wires in it). For some reason, the IDE cable has to be backward, with the drive 0 connector on the motherboard and the motherboard connector at the drive. I guess they had to do something proprietary to try to confuse people.
What you mean by blank drive. Is it absolutely fresh from manufacturer or did you formatted the drive first with windows or linux operating system? Thanks for all the work you are trying it out. It certainly helps rest of the 522 users. Also when you say no timers mean, I am assuming all the existing timers are gone, but you can create new timers for recording??
