Yes. You can transfer to your portion of the HDD.Right now have 2 508's, 1 622 and 1 222k with external DVR and am moving to a 1/3 or 2/2 Hopper/Joey setup. Several questions:
1. What are the primary reasons I would need 2 Hoppers? (record more than 3 events at the same time, 6 if you include PTAT (since no OTA at launch)? Any others? Pausing live TV is available at each Joey, as long as all 3 recording tuners aren't being used, correct?
2 Hoppers would give you extra tuners for more recording and would allow all TVs to watch live programming. After a software update the whole system with be integrated.
2. In a 1/3 HJ setup, can 4 people pause TV at the same time (3 at Joey's, 1 at hopper)? Assuming yes, how many tuners are available to record under that scenario (still all 3 (or 6 with PTAT))?
In that setup all TVs can pause TV but 2 TVs would have to be watching the same thing or one would have to be watching a DVR show. When PTAT is in use 1 tuner is being used to record the major 4. I'm not sure if you get to watch one of those shows on that tuner.
3. per the earlier post, will a 2 Joey system be supported (with Duo Node) at launch?
I'm assuming you mean 2 Hopper. If so then we do not know yet. I have yet to see a duo node as they are backodered. 2 Hoppers will not work until that is available.
4. assuming no on question 3, do I have to wait on the DIU upgrade if I want a 2 Hopper system?
If duo Hoppers are not available yet then you may want to wait. I'm waiting until I can put 2 Hoppers in.
5. What's the buffer on a joey (how long can you pause live TV before it unpauses due to a buffer running out?)
1 Hour
6. With PTAT, will all shows on ABC, NBC, CBS and FOX record between 8-11 EST 7 days/week? Does this work like on demand (select PTA, pick network, pick shows)?
Select PTAT and it will record the 3 hour primetime slot on the ABC, NBC, CBS and FOX stations that are abailable in HD to you. You don't get to pick networks or shows.
7. If I have a show on PTAT that I want to keep to watch later, can I transfer it to my Hopper storage (when I'm not using all the tuners?) Basically getting around 8 day limit for PTAT shows I'm behind on watching
jgATL said:Scherrman, thanks for quick response. Unsure on question 2.
So I thought in a 1H/3J system everyone could watch something different and everyone can pause when they want (since buffers exist at each Joey).
Assume Hopper is in Living Room, Joey 1 is in kitchen, Joey 2 is in basement, Joey 3 is in bedroom. PTAT is on, no other DVR recordings are active. All four are watching during PT, no one is watching the same channel.
Joey Kitchen and Joey Basement decide to pause TV (assume this does nothing to the Hopper). Then Hopper decides to record a non-PTAT show.
Wouldn't the Kitchen and Basement joeys stay paused?
Then Joey Bedroom starts recording a show. Assume this records to tuner 3 (since 1 is being used for PTAT, 2 is being used for Living room recording).
Then Basement tries to record the paused show. Assume that the basement is prompted that they cannot record or is shown a conflict screen like the existing one when trying to record a show when the other tuners are being used for recording.
Yes that makes sense...did I say something my post that implied otherwise, or were you not replying to me? If I did, it was unintended, I was just expanding on the answer Sherrman gave to jgATL about Joeys and live TV.Wait a minute there.... So if all Joeys are watching the same program on the same tuner, what happens when one presses pause? I assume that the paused Joey sits in one place in the buffer, while the other two continue in real time. It makes sense to me to treat the buffer the same way as a recorded program, and allow each stream independent control of it's pointer to it's own spot in the buffer.
dare2be said:Yes that makes sense...did I say something my post that implied otherwise, or were you not replying to me? If I did, it was unintended, I was just expanding on the answer Sherrman gave to jgATL about Joeys and live TV.
I'll have to test out but if all are watching the same tuner and one pressed pause I would think that all would pause. They are all on the same tuner of course. Are you saying that once a Joey presses pause it would switch over to it's own tuner and the others would continue watching?
Are you saying you verified this in a real-world test with your Hopper-Joey setup?When I pause the Hopper or if I am just behind live time and then go to the Joey and switch to the same tuner the Hopper is on, they both are watching the same exact thing at the same point in the show. What ever I do on the one I will see on the other. It works just the same as if two TVs were on TV2 of a receiver. They will watch the exact same thing and you will see the same actions happen on both TVs.
I just went in the TV room and tried it. When I rewound the Hopper about 30 seconds and then went to the Joey and switched to the same as the Hopper they were on the same picture that was 30 seconds behind. It makes sense to me.
It made more sense to me that the trick play functions would be independent, since they both are accessing the same live buffer.
Limited time offer
