Antenna Inputs On Back Of Voom | SatelliteGuys.US
randym431
188
Besides the digital antenna, theres also another antenna input on the voom box. Is this for cable tv/analog ota? If cable tv is plugged in, will the voom unit get listings from local cable tv? Or does voom use cable/local? My voom only lists digital ota on the guide. Not sure if voom also can include analog ota or cable listings???
VOOM STB doesn't have an analog tuner. If you are asking about the UHF input, this is for RF remote control.
I asked this same question a while back ...but no you cant get cable listings by adding the cable line to the back of the Voom box. I was actually looking for a QAM tuner built in but that would be too much to ask...alot of cable compaines broadcast their HD ch's in QAM and if you have a QAM tuner built in to your HD tuner you could pull in all of their HD offerings. Only a dream.
Signal Strength Sampling v1.1o, 6.1o Misleading
STB turning itself on?
