On the 8200, the gain shown is 14.2 DBi, but in DB, the gain is actually around 12, so if you're figuring losses for splitters and stuff, keep that in mind.
DISH might but DIRECTV doesn't because of the strut requirement brought on by the relatively large sail area of the "Slimline" dish.FYI, Dish, and I think DTV, do not allow chimney mounts. Probably for good reason.
None that I know of. As the FCC continues to sell off the upper UHF frequencies (they've stolen about 32 channels in as many years), newer allocations are having to go lower. In some areas, the lower frequencies seem to be preferred by the broadcasters.I know I've read stuff around saying that VHF is maybe being phased out slowly anyway. Any truth to that?
Think that is what I'd do. Spray paint it all to match the trim of the house.Probably a better idea would be using the wood running along the tile overhang to do something like this.
The maximum amount that you can get, The top mount is going to be the fulcrum point for a lever with the 8200 and wind load being the force applied to the lever.Any idea what a good/minimum amount of separation between top and bottom brackets would be for a sturdy install?
Right, A lot stronger.Sidenote, this kind of setup will probably be a lot stronger for the HD8200 than an under-eaves mount like this, right?
Yep. Just one or two turns. Tie up with nylon ties or tape [Scotch 33]do you mean just circle the cable into a physical loop and tie it off like that?
If just feeding that coax with the antenna? or making a ground connection? If just making a ground connection, if it's grounded, I think you'd be safe. Maybe not to code, but I would feel safe with it.The way I'm thinking about doing it is just plugging into the coax cable running on the side of the house in the bottom right of this picture
Limited time offer
