Antenna | SatelliteGuys.US
Antenna
Possibly one of the worst antennas you can buy. See what you need in range by going to www.antennaweb.org List your stations for better recomendations pertaining to your situation Plus are you having the antenna outside, inside attic or can you get by with a set top indoor.
Indoor antenna - Zenith Silver Sensor
Outdoor Chanlel Master 4228 UHF only
Distance and obstructions make a difference.
