I'm on the South Shore. Tim Rudolph is a bit closer to town and he's a moderator here so maybe he'll chime in. My install was done by Installs Inc., the installer was based out of Rhode Island. I don't know who you may get where you are but Installs did a fine job for me. There are plenty of resources in this forum worth looking over. Sean Mota has put together quite a bit of info in this thread which is invaluable http://www.satelliteguys.us/showthread.php?t=2052telekol said:Considering adding VOOM, Like to know about boston area installs, OTA reception , any anything else you may feel I should know.
I am in Dorchester and have been installed since December 19. OTA is great I get all the Boston Channels, but none of the NH ones that they have me map for. My install was done by installs inc, a guy out of NH. He knew what he was doing and I was up and running within 2 hrs.telekol said:Considering adding VOOM, Like to know about boston area installs, OTA reception , any anything else you may feel I should know.
rc
My list of locals:reedl said:As to OTA HD, I get 2, 4, 5, 7, 25, 44 pretty much all the time in HD. 38 for some reason has problems. 56 is just too low power to get reliabily. I also get 50 from NH.
Interesting. I get a channel 5.2 but it is always a weather map but has the audio for 5.1. I have never had reception on 7.2 but it is in my channel map.reedl said:I have never seen a WHDHDT-2 at all, only a single channel 7 digital at all.
I think that it is wrong since it only has one feed for CH: 5 and two for 7. It is the other way around.
owlbox said:HD set arrives tomorrow. Think I'm going to call Voom and give it a try. I assume if they come out and find they don't have a dish mounting point with a clear path to the bird that there is no charge.
Limited time offer
