Any luck going back to turbo after upgrading? | Page 2 | SatelliteGuys.US
They do. Scroll ALL the way down to the bottom of this page...
HDTV - High Definition Programming Options
I went there and it doesn't show on that page. I've checked their website and it's not listed.:confused: Must be my computer, browser...I don't know?
It doesn't really matter to me because I'm not upgrading programming anyway. Just can't figure out why the Platinum isn't advertised when I go to their site.
This old fart doesn't see Platinum HD or any of the channels in it anywhere on that page............:confused:
Ed
You don't see this there?
Dish is sneaky :rolleyes:, if you are a customer they display this page instead (NO Platinum):
'http://www.dishnetwork.com/turbohd/customer.aspx'
If a non-customer or no cookies you get this page:
'http://www.dishnetwork.com/turbohd/default.aspx'
If you want to view the "default.aspx" (the one with Platinum) you need to clear your cookies first.
Signal goes to only one TV
Timers for 12-1-2009
