You can't so that with the Hopper, it's 1AM unless you are recording something at that time.
doesn't it pop up a message asking to allow the update if you are watching a program?
I know one can simply answer no to the prompt but then you don't get the update at all.
The update will retry on the hour if the request is cancelled, and will continue to try untill it can update. So if you tell it no at 1AM, it will retry at 2AM, ect...
ralfaro said:Thanks, that's good to know. I do seem to fall asleep before the next popup. Glad that's the case but would still like to see this be configurable by the user.
Limited time offer
