OK, I will state that one really needs to know how this works to fully understand it. The Echostar satellite stream send a signal too...this is referred to as the PID stream. This data contains a lot of info such as firmware rev, guide data, SAT TOD (Time Of Day), etc...The PSIP is transmitted via OTA and contains similar data. The PSIP data is not alway complete or accurate. This is probably one of the reasons E* chose not to use all the available PSIP. PSIP is pretty necessary and controls OTA channal assignment mapping on the OTA 8VSB tuner of your 811. Yes PSIP is capable of carrying guide data but not as far out as E* customers require. That is why E* combines the data from PSIP and PID. PSIP is supposed to control assignment mapping, guide data, TOD, Subchannel assignment, frequency, etc....But like I said it's not always there and complete, in fact it flakes out every now and then...as some 811 users found TOD drifting...even months off the target, channels rearranging themselves, etc...This it a characteristic of PSIP derived data. Dish supplies the guide data and now TOD, from data supplied by agreement with the TV Guide channel, thru PID to compensate.mdonnelly said:I'm not trying to be obstinate, I'm truely confused. Why does Dish have the right guide info on their locals, but the OTA guide is incomplete? Say it simply, as if to a backward child.
Getting closer, but no...I'm sorry I lost ya...Yes the PSIP should and probably does contain Guide data, but it is not 44 hour plus. PSIp is required for channel mapping, station Identification, Time of date, etc...E* doesn't use all of the PSIP delivered guide data as it doesn't go out far enough to make us happy. It uses both the PID and PSIP together to provide 44 hour OTA data. PSIP is required for many reasons but is only like a checksum for EPG.mdonnelly said:Okay, now I understand. Dish local guide data comes from the TV Guide channel, and 811 OTA guide comes from the station via PSIP.
To elaborate the TVG comment...it was the TVG agreement and datasubsets/structure that helped make this information available.SimpleSimon said:No. You still don't see the light.
ALL guide data comes from the 'hidden' channels, not the TVG channel, not the PSIP stream.
The trick is how to match the guide data to the actual channel row in the guide - that's what the PSIP is used for.
Maybe someday PSIP guide data will ALSO be used, but remember, it's only good for a few hours into the future - not the several days that you can get with an E* DVR.
nippjas said:I give up, I tried to explain it several times between multiple threads and forums now. I'm burnt out, tired, grumpy, and I guess my info sucks and you just need to call Diishnetwork and get your own. Try 800 333-3474 see if you can talk to someone in the US none-the-less Denver.
nippjas said:I also stated they have issues with the way they translate and use the info. They are not using the entire data set provided by PSIP, only a portion.
Now lets see how long it take them to do NBR....jsanders said:Sorry about the misunderstanding nippjas, I completely agree with you, it does use part of the PSIP data set. I was really just referring to the guide info which they get from a provider. Absolutely, you are right, they use the PSIP data to grab the call letters, and the channel assignment mapping. They use that data to associate the channel as an index into the programming guide.
Unfortunately, with the 921, they are just re-mapping the analog program guide onto the digital channels. No sub-channel data. The analog doesn't always match the digital broadcast either. They could have done this hack back in January, well before they added the infrastructure the 811 uses to do it right. It just amazes me that it took them a year to do such a half baked fix which would take all of an afternoon worth of programming.
Limited time offer
