I'm still considering Voom. Anybody in the Louisville, KY - Southern IN area have any input on installs, OTA reception, etc?
Neutron said:Why not order Voom? I like their no committment no contract $0 up front offer. That's what I took advantage of.
QUOTE]
The $0 deal is appealing and I still may try while it's still offered. I just don't want to pay the install (cable fishing) fee and it's been nice having NO bill since we moved. The wife is getting antsy after having nothing for a month and a half.
My antenna (Winegard HD7210P) is in my attic. I had it installed before I got VOOM. I only live a few miles from Floyds Knobs where most of the digital towers are so I get WAVE-DT, WHAS-DT, WLKY-DT, WDRB-DT, KET-DT perfectly.Neutron said:Rick,
Since you live in New Albany, which is kind of like Jeffersonville as far as distance to Louisville goes, how well do you pull in the OTA channels? Are you using the standard OTA antenna that Voom is installing? Did they diplex it in with the Voom?
milhouse said:Neutron said:Why not order Voom? I like their no committment no contract $0 up front offer. That's what I took advantage of.
QUOTE]
How would you have to have the cable fished? How do your cable lines come in from the outside? If your cable lines come outside like mine do, they can use that.
You have until July 6th to get the $0 up front cost. No install fee. It's worth a try anyway since there is no committment.
Rick214 said:My antenna (Winegard HD7210P) is in my attic. I had it installed before I got VOOM. I only live a few miles from Floyds Knobs where most of the digital towers are so I get WAVE-DT, WHAS-DT, WLKY-DT, WDRB-DT, KET-DT perfectly.
Back when I was installed (December 2003) there was much talk about the diplexer causing problems so just to be safe, I requested that Digital Dimensions run 2 lines and not use the diplexer - which they did at no extra charge. The even did a wall fish for me at no extra charge (turns out they could have).
I get UPN via WFTE-DT, but I cant get WBKI-DT ... I can get the analog WB signal.Neutron said:Do you know if our UPN and WB stations come in over HD as well? If not can you pick up the analog ones?
I'm not sure what other city you're looking for ... the louisvillehdtv.com site has links to Lexington and Bowling Green... you might try looking in the "Local HDTV and Reception Forum" on AVS. Here's a link to the Louisville thread:Neutron said:Do they have other city HDTV sites?
Neutron said:How would you have to have the cable fished? How do your cable lines come in from the outside? If your cable lines come outside like mine do, they can use that.
Limited time offer
