Apartment Installation | SatelliteGuys.US
Neutron
Founding Supporter
18,716
1,124
Texas
Has anyone here had Voom installed in an apartment? What do they do as far as the OTA antenna goes? If they use a tripod, how do they secure it?
mine is in an APT, the antenna mounts to to the dish using the same mount, think of it as the letter "T" as far as looks go, no additional tripod is required for the standard antenna provided, however if you need an upgrade you will need a tripod for the antenna
i use concrete block 4 in or the 8 in either one will work
I also live in an apartment, and my OTA antenna is mounted just as Drako described.
Rain Fade
OTA Module Gone Bad?
