Archiving to DVD; increasing Tivo storage | SatelliteGuys.US
elpingumayor
A couple of questions:
1. Can I get a USB-to-Ethernet cable, connect the Tivo to my router, and "see" the content I've recorded on my home network? I'd like to archive the content on DVD but all I have now is a PC DVD burner, not a standalone.
2. What is the easiest way to increase the storage on my DirecTivo DVR?
My model is a Samsung DVR 40GB.
Thanks in advance!
Increase the size of your harddrive, if your or someone you know is comfortable opening the case. Check out:
Tivo Ugrade Instructions
and
Weaknees Instructions
You can also buy a ready-to-go harddrive to just stick into the box plus several other options, available from the second link. (Note: I haven't purchased from them so I am not making a recommendation but the instructions are well respected.)
