I had a AT9 installed a few weeks ago along with a Directv supplied OTA antenna. The OTA antenna wasn't getting all the networks, so Directv gave me a credit to buy a new correct antenna. When i was installing the new antenna I noticed that my new AT9 dish's LNB's are connected to the arm that holds them with tie-wraps ??? It looks like the arm connects to the LNB's, thru some sort of bracket. Well the bracket looks bent so they just used tie wraps. This isn't noticeable from the ground since my dish is mounted on a pole about 14'. I called Directv and told them of this unacceptable installation and they are supposed to have the area manager for the local installer ( Mastec ) straighten this out. I told Directv since i recommited for 2 years that i want it installed right, as this "setup" obviously wont last...
