Technical Nightmare | Page 2 | SatelliteGuys.US
Technical Nightmare
I'm not exactly sure what you mean. The freeze lasts for 2 seconds then continues on. Sometimes happens once an hour sometimes only a couple of times a day. But it always happens. Especially annoying during a sporting event. I've hit the back button to see if the freeze is still there but it never is. I've actually recorded a show while I watched the show live. If it freeze framed I check the recorded version and the freeze frame is not there. If this wasnt the second HS17 I might think it was a faulty hard drive. All logic escapes me.
Have you seen any of the techs pull out there AIM meter and pull a reading on the Main line going to your Genie 2? I'd be willing to bet its reading in the mid to high 40's if not over 50 db.
Sent from my SM-G977U using Tapatalk
Just hit the back button on the remote and see if it stops the freezing.
No Adjusting really. The higher the decibel level. The worse the signal is, dish could perfectly aimed and dialed in, but if there are excess barrels, unneeded splitters, un approved connections, bad cabeling. It all adds to signal loss. Alot of time I have seen where a G2 is on a splitter way too big for what it needs or way too much cabeling.
On approved cabeling, approximate loss is about 6 decibels per 100 ft. of cable.
2 dbs for connectors,
4 db for 2 way splitter
7 db for 4 way splitter
14 db for 8 way splitter
So if your ODU is properly installed and dialed in. Depending on what kind you have say your sitting at around 25-27 dbs at the Dish.
100 ft of cable
Couple barrels
A splitter
Without bad connections, old cable, un approved cable you could already be sitting at 32-38 decibels at the G2. Any of the above listed and it climbs. I've seen the Genie 2 start acting up at as low as 42-44 decibels.
I have seen countless times. Where people have gone fr 5 or 6 sd boxes in their homes to a g2 and wireless minis, and no cabeling has been changed. Still passing through the 8 way splitter.
On a G2 system. If the dish is in an area where it allows, I would do a Home Run straight from the LNB to the G2.
Older systems didnt require the quality connections and cable runs the g2 system requires. The higher the db loss. The more it effects certain frequencies passing through.
On your setup. I would have a straight homerun down to your hs17 with a 2 way splitter. To add in the 4k client.
DirecTV Intro price rockets up $25, or 71%
New Roof & HR54 Wiped Out Most of my Programming!? Any hope?
