Just select the parts that don't apply and delete them.How do you trim your quotes. I would like to be able to do that
You can also highlight what you want to quote and a little balloon will pop up asking if you want to quote or reply to the selected text.Just select the parts that don't apply and delete them.
[QUOTE="NYDutch, post: 4348491, member: 190860"]Just select the parts that don't apply and
delete them.[/QUOTE]You can also highlight what you want to quote and a little balloon will
I use the low-level editor and chop up the text with quote tags.
From my understanding, when a station changes to ATSC 3.0 it will transmit on the same channel that they transmit on now (or their new one after the repack change). They will have to find another station that will carry their present ATSC 1.0 signal as a sub-channel.
Could they offer ATSC 3.0 on their primary channel and ATSC 1.0 on one of their own sub-channels?From my understanding, when a station changes to ATSC 3.0 it will transmit on the same channel that they transmit on now (or their new one after the repack change). They will have to find another station that will carry their present ATSC 1.0 signal as a sub-channel.
Absolutely correct as Trip has noted. The problem will be in metro areas with many stations finding a partner to host their ATSC 1.0 signal WITHOUT degrading the signal to unacceptable levels. Look at how bad many of the sub-channels look now. How will several 1080i channels crammed into one frequency look?From my understanding, when a station changes to ATSC 3.0 it will transmit on the same channel that they transmit on now (or their new one after the repack change). They will have to find another station that will carry their present ATSC 1.0 signal as a sub-channel.
I think that would require different transmitters.Could they offer ATSC 3.0 on their primary channel and ATSC 1.0 on one of their own sub-channels?
The two modulation schemes can't share an RF channel.Could they offer ATSC 3.0 on their primary channel and ATSC 1.0 on one of their own sub-channels?
Thanks all, obviously I'm not well informed on the ATSC 3 specs...The two modulation schemes can't share an RF channel.
With respect to subchannels, they can spread them across multiple RF channels now. Subchannels don't run on their own carriers -- they are all multiplexed into a single carrier. They are subsequently demuxed into separate streams that are indexed by PSIP data.
ATSC 3.0 is not backwards compatible with the current ATSC 1.0 standard. That is the reason all the ATSC 1.0 channels would have to be relocated to another ATSC 1.0 channel as a sub-channel (lighthoused) for 5 years if they want to broadcast in ATSC 3.0.Thanks all, obviously I'm not well informed on the ATSC 3 specs...
thanks Trip for changing the title here on satguys with NAB coming up in the next couple of weeks be sure to pay attention to alot of broadcasters etc talking about atsc 3.0 and next gentv they will be talking about HDR and my favorite 4k and 8k so there will be alot to go around, thank youI contemplated splitting it and decided to change the title (which is how it was accidentally split in the first place). Since the original question was about whether or not the repack involved moving to ATSC 3.0, I decided it wasn't really off-topic after all, but that "repack question" was too vague.
- Trip
The time for talk is over. Those who are going to do Next Gen TV better get on with it on lose any interest that they've generated.thanks Trip for changing the title here on satguys with NAB coming up in the next couple of weeks be sure to pay attention to alot of broadcasters etc talking about atsc 3.0 and next gentv they will be talking about HDR and my favorite 4k and 8k so there will be alot to go around, thank you
i totally agree with you if you are a tv station time to go with nextgentv is now so that way your audence with new 4ktvs with HDR are wondering where is that new 4k programming you have been promising.8k will be coming in hurry LOLThe time for talk is over. Those who are going to do Next Gen TV better get on with it on lose any interest that they've generated.
Lest anyone get bamboozled by community generated false hope, there's nothing in the spec that includes 8K and even 4K seems unlikely until DTV is gone. Of course if there's no UHD content to broadcast, it is all very academic. Remember 3D?
Limited time offer
