Check that AntennaWeb site listed above by 'rad' for the frequencies.Does someone have the actual frequencies being used for a specific digital channel? My OTA decoder is being a jerk and will not auto load so I'm going to put them in manually but cant find a list of the actual frequencies.
Actually I have heard tht the reaon some want channel 2 is that it supposedly can be received better with low power. I never understood why this would be.
It's easy. Lower frequencies require larger antennas. Larger antennas intercept more signal. If more signal is intercepted by your antenna the station doesn't need to transmit as much power to cover a given area.
By scanning I have indicated my local NBC affiliate WTHR channel 13 is @ 665Mhz for the HDTV signal. (the receiver read out not an analyzer) That puts it in between what would be channels 44 and 45 in the now analog UHF TV band.
It has nothing to do with larger antenna gathering more signal, it's all about matching the element size to the wave length.
Lower frequencies have longer wave length, so half-wave harmonic to pick up the frequency requires a longer element.
I had read that Ch 49 intends to move to Channel 2 and I believe that there ere threads about it at the time. But since I cannot find a reference or that earlier thread I will retract my statement due to lack of proof. I must be wrong.
Limited time offer
