Audio issues on KPBI and KFDF (g10) | SatelliteGuys.US
drhydro
1,572
Hey Folks,
Is anyone else having issues with the audio on KPBI and KFDF on g10? the audio on kpbi is gone entirely and when i tune to kfdf the audio comes on for a couple of seconds then cuts out. I have a very strong signal quality readings for this transponder, above 90 %. I have both a 10' bud and a 30 inch winegard and i have the same problem no matter which dish i use. I even rescanned g10 with my BUD, called it a different sat., so i had two sets of channels for g10, one set off of my winegard and one set off of my BUD, both stored in my reciever. I have tried rebooting my reciever (pansat 2700a), that didnt help either. Any clues anyone?
Thank you pete, i was starting to think there was a hardware problem in my setup somewhere. Oh well, hope its fixed soon.
drhydro
delete them and rescan them (just do a TP scan). Thats what I had to do...a straight rescan won't work
They will log in as "upn" and "fox" and then they work fine
KPBI works wonderfully over here (62%S/65%Q) in Utah.
KFDF I'll have to look around for, it's not in my channels for some reason.
EDIT: Doh, just wasn't looking. There and works great- probably becuase I just did a rescan ;)
Thanks Iceberg
they're on the same TP (12114 V 4444)
thanks iceberg, ill delete both sets of channels i have for g10 and rescan tonight.
Thanks, iceberg. I had the same problem, did just what you said, and it cured it perfectly.
I tuned in to see the Cardinals game, and heard the NFL Europe audio and I was like "what the heck"
rescanned it and it didnt do anything
deleted the channels and rescanned and now they work :)
I had to do that to all 4 receivers.... :D:D
Had the same problem on the Fortec Star Lifetime Ultra, did the same thing, everything is now working great. Thanks Berg... Oh, By the way, I like the new picture.. :D
Thanks Iceberg, I rescanned and now those channels come in just fine.
I guess I'm a day late and a dollar short, I meant to post, just didn't get around to it. These changed pids, so re-scan and volla.
Noob Q's.. Would I miss out alot past 123W?
Got my Fortec 100cm dish installed
