Audio Static | SatelliteGuys.US
Audio Static
shakewell
3
Hey folks... just installed my Slimline 3 .. good signal 95+ on all 2 lnb 99 103 101
i am now getting static audio on all the channels.. it kinda reduces on non hd channels but all hd channels have static.
I did not have static at first on my test cable...but when i plugged in the wall wire to the receiver its giving me static.. i did not check again on the test cable as i had already wrapped up the stuff
i have a HD DVR HR 22
any idea as to why ?
its connecteced direc to tv .. no AV devices in the middle.
So your using an HDMI cable? Can you test the same a/v connection with a DVD/PS3/XBox360?
ok folks after trying hdmi it wasnt the hdmi
one of my Wire connections from the lnb was loose
so make sure all wires are tightened up ..
Problems with local hd channels due to snow/ice
HR-22 "freezes" - reboots needed?
