Good Enough?
All this talk of overheating got me worried. I just had a 622 installed last a week ago, don't know what version nor have I checked the temperature.
I have it in an enclosed entertainment center however. But, made some modifications I hope will be good enough to keep it running properly.
First of all, there is nothing else generating heat in the cabinet (a DVD and VCR which remain off mostly; if those are playing the 622 generally then is turned off...or as off at it goes!).
I moved the 622 low in the cabinet (since heat rises!) although I elevated it on a 4" PC riser that has some air ventilation holes in it to increase airflow underneath the receiver:
I also then installed one of the antec PC laptop coolers between the above mentioned riser and the receiver (which I believe sucks heat off the bottom of the receiver rather than blow air onto the bottom of it):
I do notice the 622 is still pretty warm to the touch (not hot enough to burn your hand however!).
I also keep my house pretty much at 72 degrees year round.
Do you think this is enough protection, or do I need to take the added step of cutting into my cabinet and adding a heat exhaust fan?
I also noticed someone mentioned to take the rubber feet off the receiver if placing it on a laptop cooler to allow the metal the dissipate some of the heat. I did not do that, I figured the more airflow under there the better, that the laptop cooler was probably helping. Any opinions on that as well?
Thanks!
http://www.allsop.com/home-office-tools/monitor-printer-cpu/model-27021/metal-art-jr.-monitor-stand/
I also raised the shelf above it as high as possible, probably 9-10" above the receiver as to not trap heat released from the reciever on top of the receiver.
Thanks!
