AZBOX HD ELITE "plug in" | SatelliteGuys.US
zaxxon
SatelliteGuys Guru
132
Dinwiddie VA USA
I received my axbox elite it didn't have a manual, seller said it didn't come with one, I guess in english.
I down loaded the manual but my Adobe 9.1 keeps asking me for a "plug in"
There are a lot of plug in's out there, anyone know which one I need to print the Manual????????????
Shalom
Shalom
I think, you need Korean fonts add-on
I received my axbox elite it didn't have a manual.
I down loaded the manual but my Adobe 9.1 keeps asking me for a "plug in", anyone know which one I need to print the Manual????????????
Shalom
Yes, this is correct. Adobe Reader requires an upgrade for the Korean fonts. When I attempted to open the PDF file for the manual, I received this message, too. At that same time, I was prompted to install that upgrade through Adobe 8 Reader. If you do not have Adobe 8 or higher version, you may need to upgrade to that version first.
I converted the file for the manual with my Adobe reader and zipped it. I will try to attach it here, but I don't think it will help you to open the pdf document without the font upgrade.
I believe that the original pdf document remains unchanged, so you simply must have the support for the Korean Font in the Adobe reader every time the pdf file is opened.
But, if you would like to download the attached file to try, you are welcome to do so and please let us know if the file can be opened without the upgrade to Adobe Reader.
RADAR
How do you add TP's with an Azbox Premium?
AZBox HD Premium HDD
