Can you ping the receiver's IP address?I don't see any message, just a black blank screen
That's great to hear that you were able to get safe mode working and restore your unit!OK... I was able to get into Safe Mode. In the previous firmware version, it was a different way of getting there. Now it is holding down the power button for 5+ seconds and waiting for it to flash.
To enter a decimal point, use the down arrow key to scroll the displayed number until it goes one level below "0". Once the proper number is entered, press the OK key to save. Please note that the entered numbers won't refresh on the menu until you go Back twice which returns you to the Installation menu. Sorry that it's not so obvious but it's easy once you know about it. Now that our new firmware version is released, we will finish our work and release a user manual which would explain things like this.All seems to be functioning at the moment, but I do have a dumb question. How do you enter a decimal point into the Latitude and Longitude setting. I can't seem to get that to happen and was the reason I tried to change the coordinates last time. They were not exactly legitimate entries without the decimal included. The old version seemed to figure it out, but not in this one. So thanks... things are looking better.
You might be on to something as there could be an HDMI handshake issue which only impacts certain TV brands. Out of curiosity, what TV brand do you have?Now... I also had the same blank screen issue that scopus does after the 2nd time around with the upgrade. What I learned in my case is that my TV would detect the signal from the AzBox and power on, that is no longer the case. When I thought nothing was working, I tried turning the TV itself off and back on to "wake it up" and there it was. The unit was in safe mode all along, but I saw nothing. For some reason, my TV no longer senses that it is getting a signal after the upgrade. I hope that helps you in some way scopus, but your situation may differ.
Please hold off entering numbers on USALS at the moment as I was able to replicate your issue. There might be an issue based on the way the numbers are entered which causes the flashing AzBox starting... message.To enter a decimal point, use the down arrow key to scroll the displayed number until it goes one level below "0". Once the proper number is entered, press the OK key to save. Please note that the entered numbers won't refresh on the menu until you go Back twice which returns you to the Installation menu. Sorry that it's not so obvious but it's easy once you know about it. Now that our new firmware version is released, we will finish our work and release a user manual which would explain things like this.
I am using an older Hitachi 42 inch plasma. The "black screen" problem quit after configuring the unit and the TV now senses the HDMI signal as it used to. Go figure.That's great to hear that you were able to get safe mode working and restore your unit!
Holding down the power button for 5+ seconds until it flashes then letting go does a hard reboot, similar to pressing the reboot button on a PC. This should be done if ever the unit becomes unresponsive rather than simply pulling the plug as it avoids the risk of corrupting the flash memory.
New issue with upgrade. Audio changes on NBC channels on 103w causes corrupted or no sound. For example, I switched from aaa to aac and it worked for a time and then no audio at all. Changing channel and returning restores the audio. I also switched to aag and the sound became choppy. Switching back to aac caused either choppy or no audio at all. A channel change again corrects the audio, at least for awhile. This did not occur before version 2.0
Thanks for that info K17, something else to try when I get home again, I'm not at home at present. The 5 second power button push with the blue light flashing is also a new one on me. Hopefully I should see a picture this time.
Thanks Catamount, I might need some luck. I can't even get the splash screen on either of them. The TV on/off trick is yet to be tried.I've let mine flash up to 15 times trying to get it to boot . Let it go and still hangs on splash screen. Last few times, it's booted within three tries. I reflashed in safe mode three nights ago and redid my settings from scratch. Haven't turned it on today though LOL.
Good luck restoring your boxes, Scopus
A couple of Questons;
How do I setup the USB drive for recording. Although I was able to use it for the upgrade by just copying the file to it and connecting it to the box, I get the following when attempting to record;
ERROR:
Unable to start recording as external disk is not connected or writable.
Please ensure the movies directory on your disk exists and is writable.
I go to the System Settings / Hard Disk Drive-USB / and the drive is shown there. I try formatting (ext2, ext3 and ext4) and it says "Unmount". I go to the previous menu and select "Unmount" and tried again but it just says "Unmount".
I was also using a small flash drive fine before the upgrade, now it doesn't even know its connected. Any thoughts?
Any advice appreciated.
PWRSURGE: how do I revert back to the pervious firmware? I did a factory reset and loaded the pervious firmware, but it doesn't take. I check the information tab and the receiver reboots. I check the information again and it is still 12.18.14.
ERROR:
Limited time offer
