Bev dish pointing | SatelliteGuys.US
Bev dish pointing
ryyback1969
2
Canada
Hi all-new to the forum. Need a little help.
I found Bev 91. Now how do I find 82? I thgink I read that if you move the dish slightly right or left you would find it. Can anyone confirm this?
Thanks a bunch-:)
82W is slightly left to 91W if you are standing from the back of the dish. Your elevation and skew may also need to be adusted slightly.
I will try that then-thank you-:)
I figured it was close.
Side note--I spent some 7 hours trying to find a bird and gave up, went out this morning and had it in 20 seconds-go figure-lol
piggybacking receivers
Glitches on a few channels
