BEV/DISH SW Switch? | Page 2 | SatelliteGuys.US
BEV/DISH SW Switch?
so lets see...you ask me what models it would work with and I responded with a pretty good answer. Then you decide to be a dink and post the list WHEN YOU ALREADY HAD THE DAMN ANSWER.
Why bother asking the frickin question then? Just to be a dink and show "oh looky...I can get better info than you"?
I thought you will take the hint and add to that two models a few more.
You shouldn't be upset - the forum is for share info. ;)
OK, there is the list, with seven models what doesn't support DP LNBF or DP switches:
PID: 0861h, ID: 25HX, FW: E529, Model: 4700.
PID: 0863h, ID: 0EQX, FW: E518, Model: 3750.
PID: 0870h, ID: 0QFX, FW: E502, Model: 1000.
PID: 0878h, ID: 0MNX, FW: E534, Model: 6000.
PID: 0888h, ID: 10CX, FW: E522, Model: 4000.
PID: 0889h, ID: 0XBX, FW: E513, Model: 3000.
PID: 088Ah, ID: 28GX, FW: E582, Model: 2700.
I mentioned anything made in the last 4 years or so will work. When I had EVu 4 years ago the only Legacy receiver they sold was the 6000.
Most people probably have upgraded their receivers from the old ones :)
And for the non-technical people here is what the above means to us "common folks" ;)
4700. 3750, 1000, 6000, 3000, 2700 & 4000 wont work with the DP34
Installing a 4 (or 5) X8 switch
Older Sat RCVR Model 3500 problems
