Brazilian package will be off from 61.5 sat? | SatelliteGuys.US
Well if you are truly at where your location says (Salt Lake City) :rolleyes: you wouldnt have a EA 1000.4 dish. If you were truly in SLC all they would do is switch it to a Dish 1000+ which sees 110, 118, 119, 129
But you will need a D500+. The older style had 2 outputs on the 118/119 LNB. Hook the 118 output (1F) to the input on the EA 1000.4 dish
Reactions: RonaldoAntena
I have Dish NetWork 1000.4 to get
my Brazilian Elite Package on 61.5 Sat
and some local channels!
My question is : I must have to upgrade
to dish 500 plus ?
When Brazilian channels wil be off
from 61.5 Satellite?
ThanKs!
Yes, the channels will be removed from the 61.5 satellite. This is supposed to happen within a few weeks. Currently, you can view the channels on 6831-6835.
Depending on where you live, you would either need a 500+ (1000+ if you have HD channels), or an eastern arc dish with a 118.7 wing dish. If you PM your phone number or account number, I can check for you, or set up an install to have a tech come out
211 versus 211K
Dish wants to come out for a "courtesty" check, what's up?
