Broken 301 ? | SatelliteGuys.US
Broken 301 ?
Dans97
7
Need some advice. Have two 301 rec. ,one was disconnected for maybe a month. Now after it was reconnected it will only receive maybe five channels and everything else says that the smartcard is not enabled for this channel. ck of the signal says all three sat. are being received o.k. . My daughter took it upon herself to call a csr and he said " it's broke honey , we'll send you another for $49.99". What gives? Smartcard?
Thanx:eureka
Actually if you leave it connected overnight it should receive the reauthorization without calling if you're willing to wait.
Yep just get it re-hit I run into this all the time.
why are my local ota hd channels fuzzy?
Having Trouble Finding This Info...
