I am testing a mini Bud. Testing BCS621-2 on 1.2m with sg2100. So, we will see.
Welcome!
I made some 1/2" polycarbonate rings on yesterday. They turn out okay. I, then made the modification to the the bsc621-2. So far no difference. The c band side still works, but the ku is still not working. I think I may be a little off on my focal point on the ku side. I will do some fine tuning this weekend and try again. Pictures of my mod with 1/2" poly rings coming soon.
I don't see why moving the Ku LNB should improve performance.
Seems like it should decrease Ku reception.
Out of sheer accident, I noticed that using this LNBF (BSC621-2) with a flat scalar ring on a mini-bud (1.2M) that you can substantially improve the reception signal quality in the C-band spectrum with another rather unique modification.
While trying to adjust the scalar ring position, I noticed that the signal quality on C-Band was substantially improved when my finger-tips were just barely over the outer scalar ring. I mentioned this to Walrus and he experimented a little with this and found that it also improved his C-band reception.
Basically, out of curiosity I guess, Walrus grabbed whatever he had on hand - a metal socket that just fit in this outer ring snugly so that it would stay in place - and found the results desirable if the socket was placed in the right spot.
It therefore appears that some sort of parasitic element, properly positioned in the outer scalar ring, will improve the signal on at least the C-Band signals for a mini-bud dish.
I thought others might like to test this out for yourselves, as well as the modification that Minimo has mentioned.
I wonder if placing a thin, short aluminum tube (same diameter as the outer ring on the rear assembly of the BSC621-2) when it is extended would help as well.
RADAR
Yes, and several years before that, the guys on the forum were making up conical scalars. -If you look back at Satcom1 mini-BUD posts, he describes this about two years ago. what's old is new. There were pics.
I notice during my test on both dish , if in the bracket i tilt the lnb body at one position
quality raise to interesting number 90%. At the same time i lost the c band , this is not a
pratical solution.
Since i made the mod i see no degradation on c band.
Any comments welcome.
Nick
Limited time offer
