C-Tech 5000 HD Combo Plus | Page 2 | SatelliteGuys.US
EDIT: I tried to import into Channel Master using Coolsat Wizard, did not work. NDFEdit is easy to use though.
Yea, I tried that, seems not all ndf files are the same. Like you say NDFedit is easy to use, I've been playing with the Lyngsat update, seems to work pretty well....just not the same as dvb-s2 blind scan though:D
Lnb question /Signal amp ???
New Coolsat firmware.
