Camper setup. | SatelliteGuys.US
Camper setup.
Hockeynut
850
744
Sat Farm in NC.
Have an H20 DVR and a H25 receiver...Like to watch tv in the front of the motorhome along with the back bedroom...G2+ Winegard is the Antenna...What is the best way to make this work....Granted I know I am dealing with SD in this setup..Thanks for any and all input.
The H25 needs a swm setup to work. Unless you use a swm switch in line, it's not going to work. The HR20 just needs to be connected to the antenna at the input that says FTM (IIRC) after you disable the second tuner through the setup menu.
Reactions: Hockeynut
Regional Sports Fee
DirecTV Setup
