Can a dish like this be used for C Band? | SatelliteGuys.US
Attached are the images at that link. The text reads as follows:
"This is an outdoor (in protected weatherproof box) LTE cell modem, router that I used to get internet when I couldn't get cable internet. You need to get a SIM card from your cell carrier and unlimited internet.
4G LTE Rugged Metal Enterprise Router with Embedded SIM for AT&T or T-Mobile including band 12
Verizon Sprint TMobile LTE2 LTE Advanced Cellular Modem
T-Mobile recommends using this router as this is the best and fastest product on T-Mobile
Included 2 x MOFI-UWMB-MAXRANGE1 Upgraded Cellular Performance Antenna
Extended WiFi Range with build in Wireless Repeater Mode
Comes with 10' C band dish that I used to grab signal."
Sent from my SM-G950W using Tapatalk
Reactions: FTA4PA
I tried to view the listing but it says it is no longer available. Hope you got it if you were interested? :what
No, I didn't get it.
View attachment 151806View attachment 151807
I guess I did not see the mention of "C Band" when I looked at it.
  • Sad
Reactions: FTA4PA
Good use for a C-band dish reflector, nice to see people are creative when making things work that normally won't. Sorry
Route66Fan you didn't get the dish though would likely have worked well.​
Reactions: FTA4PA
