The Broadband setup or the Dishcomm setup?
Broadband setup is all you need to set.
Dishcomm is a setting that allows multiple receives in your house to share the phoneline with each other so you don't need to have a phoneline in every room that has a receiver.
Dishcomm uses the homeplug technology but you do not need to do anything with dishcomm to use the homeplug technology (Sling link) for broadband.
I have two 211 receivers hooked into my home network using Netgear PLC adapters. Lan connections test at over 60 Mbps. Works fine and both my receivers can call home and be used to order PPV.
I am a big fan of the PLC technology and am migrating many of my networked devices away from WiFi. PLC is more stable and less trouble to keep on line.
You can often pick up factory refurbished adapters at Amazon for $30.
or, brand new for $32 from dishstore.net....
THE VIP RECEIVERS HAVE IT BUILT IN!! that is what DishComm is all about! That is, after all, what you were asking about in the first place.
Buy ONE sling adapter, plug it into the wall near the router.
plug the router into it.
make appropriate adjustments in the DishComm and Broadband menu on the satellite receiver.
Enjoy.
You've found Satelliteguys. NO reason to read any other site for Dish information.
Limited time offer
