Can I get 4 lnb's with DP34+DP21? | SatelliteGuys.US
orpheus
12
I have a 121 Superdish on DP34, but I'll like to also get locals from 148, so, can I use a DP21 switch to combine the output from DP34 with output from 148 lnb? The receiver is 508 with latest software.
Thanks.
Yes that will work for 1 receiver. If you get an additional receiver then you will have to run an additional feed from the 148 lnb to an additional DP21.
Why does E* HD PPV suck compared to D*?
Dish 522 Reception Problem - Sat 119
