can somebody tell me when is dish | SatelliteGuys.US
ahh, here is the second post from the guy posting the same question in the HD-DVD/blu-ray forum.
Why do you have to switch sources on your TV? How are you getting HD locals? OTA or cable? If OTA, why not hook up the antenna to the dish receiver, I assume it's HD also.
If cable, then ok you gotta switch sources, but is it really a hard thing to do?
gonna have local hd channels im tired of switchin sources in my tv please let me know
If I had to guess, I bet you have the antenna hooked up directly to your tv rather than through your e* receiver. That would make sense if your box is not an hd box, but otherwise it makes more sense to run it through the e* receiver. It will integrate your ota HD channels into the guide and if you get (non-hd) locals through dish, it will fill in the guide data (as long as it matches a channel that E* transmits to you.)
Will Dish Retain the Title "HD Leader"?
DISH Network manufacturer?
