Can't get 110 sat | SatelliteGuys.US
Can't get 110 sat
jameszeesmith
8
st. louis
I got a disk 500 and dual dp plus digital lnbf. I'm running r-59 cable from port 1 on lnbf to a 301 receiver... simple setup. I only receive sat 119 on port 2. Port 1 says conn
Manual says to move dish 10 degrees East and try again. I tried but can't get no signal by moving dish 10 degrees. I can't seem to pickup anything but sat 119 at 214 azimuth for 63146.
I know that I should have 3 gh r-6 cable eventually but for my testing I just ran the r-59 through the window.
Also, what does x mean in the polarity column 1 and all in polarity column 2
Status line says: Only one satalite connected.
I can only get the upper channels on 119.
:) Thanks in advance guys, Jim Smith - St. Louis
CONN means it's connected but not receiving signal. Polarity "all" means you're getting both odd and even transponders for that particular sat above the all.
I would get the RG-6 for testing purposes as well.
I agree, I had a piece of RG59 in my system when i hooked it up and had signal problems. Changed it to RG6 and the signal was great
you said you are using a dual. i assume you mean twin? fatter lnb with two 'eyes'. is it used, those can go bad as well. though i still suspect its an aiming issue. as gary said, it may need to go west.
if you really ARE using a dual, you can't use it to pick up 119 and 110 at the same time.
if its dp plus, its definately a twin. is it possible that something (house, tree) is blocking the 110 signal? did you put the dish up yourself?
Can you use a Dish-TV dish with Direct-TV?
Dish Home Protection Plan
