Can't get G10r | SatelliteGuys.US
Can't get G10r
mdmm
33
As a new person I wanna try to get Galaxy 10R at 123.
I have a universal ,Linear LNB and 33 inch dish in size.Please correct my following LNB setting for south ontario,
My setting is this?????is it ok??
Dish size= 33 inch
LNB type= standard
LNB Frequency= 10750
Best TP= 11800-v
Can i get some channesl on TP= 11965-v
Hello mdmm, the dish should be fine, but if you have a universal lnb use
LNB type = universal
Lnb frequency = 9750/10600
Dish size is fine and 11800 is the strongest transponder and yes you can get the channels on 11965.
Since you didn't give exactly where you are here are the co-ordinates for Toronto:
Elevation:23.6°
Azimuth (true): 234.1°
Azimuth (magn.): 244.8° using Compass
LNB skew: 35.9°
Good luck with your setup.
mdmm, if you are in the Southern Ontario area near Toronto, you will also be able to get WNGS from TV antenna as they are a sub channel 7-2 of WKBW-7 digital.
3 LNB Yoke on Dish 500
Will this dish work for fta?
