cant get G25 | Page 2 | SatelliteGuys.US
cant get G25
Polarization explained, the wordy version
13 volts at the LNB = Vertical polarization (or Right Hand polarization)
18 volts at the LNB = Horizontal polarization (or Left Hand polarization)
Needless to say, circular polarized (pay TV) satellites use R & L, where as standard linear FTA satellites use V & H.
But, the receiver controls the LNBs the same way, using 13 and 18 volts to select between the two available polarizations.
HI, guys can somebody tell me please I have a globecast dish i would like to know if i can add another Lnbf next to it and if i can do so what type of satellite i should looking for with that second Lnbf, beside intelsat 5 i am looking for
the invacom is a universal and the one that came with the dish is single
you really need to switch to decaf :rolleyes: Just because someone doesn't post like 6 seconds after you do doesn't mean to bump the thread up and respond with a HELP ME thing or repeated info. People read the threads and add info if need be
now that we got the PSA out of the way :D
With a 2nd LNB you can get maybe 6 degrees offset from either side. So if the LNB is at 97W right now you may be able to get 91 or 103 but not much more beyond that. When you go off centre the signal is weaker because its not getting the full signal from the dish.
Thank u please i am new in here that's why i have done it or repeat . what is 91 or 103 and what would you recommend me add another lnb or no
no need to repeat stuff. Folks can read from the top on down :)
those are two other satellites up in the sky and they are close to 97W. If all you want is ethnic channels then 97W is the best satellite.
I903? not on that same dish. Too far away. Most you can get away from main LNB is 6 degrees on either side
ethnic channel....channel that is not one of the three major (and I know I'll probably hear it from someone) languages of North America which are English, Spanish, French
97W has a fair amount of foreign language channels on it (as you probably know by now) :)
would it be possible for me to get intelsat 903 and what is the setting i lived in Florida my zip is 33313 can somebody tell me would i be able to get it with my 36" dish what would be the skew if i can get it do i have to add anything to that skew
i mean you don't have to be mean about it if i ask just a question, i really like you guys help but no disrespect one and other, what about if i don't take the I5 and i go for I93 instead would i be able pick that and what would be the setting zip 33313 and what would be the skew do i need to add THE SKEW WITH 90 OR
I 903 has nothing on KU Band that is aimed towards the US so no need to aim there
C-Band has some stuff but you need a 6 foot or larger dish
i would love to watch Nigerian tv plus order African tv can anybody tell me what would be the best satellite to aim and would it be possible to get it with my satellite dish 36"
Name: 101W, 110W(c), 119W​
Distance: 37412km
Motor Latitude: 26.2°
Declination Angle: 4.4°
Dish Elevation: °
Elevation: 45.0°
Azimuth (true): 232.4°
Azimuth (magn.): 238.2°
LNB Skew: 45.3°
Dish Skew: 44.7°
Can anybody tell me do i need to add that 44 to 90 and other to get the skew or leave it the way it is
Distance: 37412km
Dish Elevation: °
Elevation: 45.0°
LNB Skew: 45.3°
Dish Skew: 44.7°
what does that have to do with picking up 97W and why do you keep going back to DirecTV sats? They are different things and pick up different satellites
If you are trying to get 97W on the Globecast dish, then lets keep the posts about that
Let me put it bluntly:
Receiving (99% of) DirecTV on any receiver but DirecTV supplied is illegal by international treaty law and on this website is called "Hacking". It is not tolerated. Please stick to FTA FREE to All people or Free to Air signals.
The same is true of Dish Network. A few legal free to air but not enough for most people to deliberately go after.
Directv cant be hacked :)
:up very true
Hi, guys can somebody tell me what to do cause i can get I5 when i plug it to the receiver i can get no Q what so ever i swing it and i even hold it off the base after word i still can't get not even other satellite which i assume will be close by but nothing at all just the S moving but the Q still .. I had that dish for a Year and Months never tried it but Today i did try it but i don't know if it's not on the Lnb which i don't want to say something i don't know about so y'all expert help me out
Red lnbs , haha
Cuba Vision on Hispasat 1D @ 30
