Can't Get Locals on 110, Spot Beam 4 | SatelliteGuys.US
reddybp
4
Has anyone had a problem with their system connecting to 110, Spot Beam 4? Tried hard reboot and will not connect. System Info shows all three satellites on the super dish okay.
Buddy is on the phone with me right now from DFW, asking about hes Dish system. SAT 110 spot LIL are all out but everything else is working.
EDIT: his is transponder 20
Seems like its just you and him though (LOL) from the lack of replies here. I told him I would come here to help him out; hes been down for almost 30 mins or so. says hes done the check switch and its OK; also has other transponders on 110 that come in fine.
Have the same problem in DFW looks like almost all spot beams on 110 are going on and off. Just talked to my son in Sherman Tx and his is doing the same thing.
Just talked to Dish Network they admit that they are having spot beam problems in the Dallas area and are working to correct the problem.
Advice needed on swithching to Dish
Question about LiL
