Your method wont work on the older H/HR2x receivers.
it works just fine not waiting; I have a HR20 and H21 and can tell you for 110% sure.
Since switching to HDGUI, I can't get the 0-2-4-6-8 to work at the start of the blue light on my H/HR21s. But the blue screen right after a RBR is almost perfect. And that was working well until this last CE. So it would be back to drawing board. But . . .it works just fine not waiting; I have a HR20 and H21 and can tell you for 110% sure.
I'm getting a HR34. When it arrives, I'll be retiring almost all of my H/HR21s. The only one left will be left on NR. So my 0-2-4-6-8 timing nightmare events are hopefully over.
When you send. report to D* what do you do with the report code they give you?
You fill out a post here. Using the following format with your specs
Receiver: Hx2x-xxx
Report No.: 201112__-___
CE: 05__
MRV: Yes/No - DECA/Ethernet
TV: Manufacturer - Model Number
Connection: HDMI/Composite
Issue: Subject - Description
Scott Greczkowski said:No reason to send people to a different site, DIRECTV reads here as well.
Further comments to go to another site to report DIRECTV issues will be removed as spam.
Still no channel logos, but I do have the program logos???
Anyone else having issues with the Apps not coming back?
Limited time offer
