Crossing fingers for you too... did you try the clearmybox 2 code?My fingers will be cross for the return of my Genie missing My DIRECTV Group.
I noticed mine had it before I started downloading 0983 on it...My fingers will be cross for the return of my Genie missing My DIRECTV Group.
Check it in the morning.Well after download, I'm missing a ton of channels and the audio is breaking up like crazy on my HR34-700 Genie.
And the My DIRECTV is still empty.
Doing a CLEARMYBOX. If that doesn't fix the missing channels, I'll do a 2xRBR.
What does that do over just CLEARMYBOXCrossing fingers for you too... did you try the clearmybox 2 code?
After the download is installed, your receiver will be doing several things after rebooting, including downloading guide data, VOD channels, rebuilding To-Do lists, etc. It is normal for your receiver to appear slugish for a while after installing software. You may also have timers that appear missing, etc. Do not worry, as the receiver rebuilds the data over the next few hours, your timers will come back.CLEARMYBOX is finish. Have mo' channels missing now. Audio is breaking up on all channels I tried.
Limited time offer
