AZBOX - Changing the radio icon to a black screen on the Azbox | SatelliteGuys.US
AZBOX Changing the radio icon to a black screen on the Azbox
stargaze
916
56
Out there somewhere
Ever want to change that radio icon on your Azbox to just a plain black screen?
I have done it here on the Premium Plus and Ultra receivers.
The black screen shot picture is located here:
https://sites.google.com/site/azboxtools/home/changing-your-radio-icon
and the actual instructions are :
The directory the radio icon is located in on The AZ box using the normal firmware
is located here in the azbox...
/MMP/hd/Program/Image/TV-TD210/main
the file is called: radio_bg.png
First open Maz and click on Telnet
then find the tools Script drop down box and
click on...
enable Write in MMP
Then go to FTP and click on
"MMP"
then "hd"
then open up "Program"
then... "Image"
then open up... TV-TD210
then open up... main
The file you want to replace is named
To replace it with a black screen
download it to your computer and using Paint select the picture and delete it.
Then invert the color so it goes from white or clear to black and save it.
Or just use the picture from the website in the link above.
Now since you have already
went in Maz and did the Telnet enable write in MMP
your ready to send the new file back to the AZbox.
once you transfer the picture exit out and your done
Your Radio icon is now a black screen on the AZbox.
Enjoy!
Nice to know some people prefer a black screen for radio mode. We will try to add this as a settings option in future firmware versions.
Regards,
PwrSurge
AzBox Canada
Stargaze,
Have you tried to save other images (as opposed to the original or just a black sreen) to this file? Do you know what the video size/resolution limits are?
I think it would be a novel option if you could save a theme-based picture or photo here, but I am not sure if this files dimensions would allow it.
RADAR
No Radar, I just wanted to get rid of that screen from the display when on a radio channel and used a black screen.
I do believe there is a file size limit, Tried to send a pain black image to it first but it would not take it so then took the original file and worked on it to turn it into a plain black screen and resent it back to the receiver.
Since my desired results were achieved, I stopped.
AZBOX No image after Sleep Mode
GEOSATpro MicroHD Counterfeits?
