You DO NOT have an Android t.v. box, you have a box that runs MOBILE Android OS that connects to the tv. Looks like you are misleading peopleBeelink GT1.
That box is running android, but it is not running the android tv software, which this device is.Beelink GT1.
Which goes to show how important it is to be specific. I expect that very few know the difference between an Android TV box and a TV box running under Android.You DO NOT have an Android t.v. box, you have a box that runs MOBILE Android OS that connects to the tv. Looks like you are misleading people
Do the new TVs that run Android TV as their OS logically qualify?
My point remains that your posts were misleading because they implied features that aren't available in the discussed hardware. Extrapolating on this misinformation to suggest that some other product should be capable of similar functionality is a double-whammy.
Extrapolating that the Stream+ must be able to use USB storage based on a combination of largely unrelated third party products isn't reasonable. Scott reasoned that Netflix would obviously be available because it is available for pretty much every other Android TV device (as well as most of the Android devices) but we know that's not happening right away.None of my posts are misleading, Android tv 7.0 has Dvr support and the Usb port CAN be used
So you can attach an external hard drive to this new device instead of the micro SD card or do you need it too?I read it to allow microSD and/or USB3 storage.
The available documentation from Channel Master clearly says (in the above quoted press release and on the above linked product page) that the Micro SD card is required, that it will be formatted before use and they show a 128GB card (not many hours of MPEG2 HD) among the accessories to be offered on the Stream+ product page.So you can attach an external hard drive to this new device instead of the micro SD card or do you need it too?
So basically you don’t need the external hard drive at all. I want to know how big is the SD card relative to say a 1tb hard drive. How many hours would you get using the SD card?The available documentation from Channel Master clearly says (in the above quoted press release and on the above linked product page) that the Micro SD card is required, that it will be formatted before use and they show a 128GB card (not many hours of MPEG2 HD) among the accessories to be offered on the Stream+ product page.
Channel Master doesn't appear to have made any reference to USB storage.
On Technicolor's "Skipper" page, they say "Media sharing functions using a USB 3.0 port for plugging of HDD". To me this suggests that mass storage support is there for moving content on and off. The Skipper features list doesn't mention DVR functionality.
Until the device gets into the hands of someone who can talk about it, any claim one way or the other is speculation and new features may or may not be added later (much like Netflix).
It isn't directly relative because DBS DVRs (such as the Hopper) record satellite content in MPEG4 and this device records using less-efficient MPEG2 compression (just as the Hopper does with an OTA adapter).I want to know how big is the SD card relative to say a 1tb hard drive.
That depends entirely on the capacity of the card that you add; it doesn't come with one.How many hours would you get using the SD card?
The Techhive article literally says that Channel Master is planning USB 3.0 hard drive support and that at this time it suffers "playback issues and other glitches".From the article I mentioned earlier, I suspect after a bit of a wait, USB EHDs acting as DVRs will work just fine.
The real issue with flash storage is that you're not supposed to fill it with more than a certain percentage full so that the drive isn't forced to reuse (and use up) the few free storage cells that remain. DVR has never been a good application for flash memory and not much has changed on that score. That said, security cameras can use flash because they're only recording short "incident clips" that are automatically aged out as new clips come in; a relatively ideal situation.It simply would not be a very saleable unit if the only DVR option was a very expensive chip, and one that might not last as long as spinning platters.
This is covered on the Channel Master Stream+ web page (second link in the first post of this thread). Look for "full technical specs"Does it support Dolby Digital Plus via HDMI or al least DD?
Simple yes would have sufficed...This is covered on the Channel Master Stream+ web page (second link in the first post of this thread). Look for "full technical specs"
I'm not sure I understand placing the value of "discussion" over teaching people how to fish.Simple yes would have sufficed...
He asked a question, you didn't answer it. That's his point.I'm not sure I understand placing the value of "discussion" over teaching people how to fish.
Limited time offer
