Not for me on my HR20. I just set up a favorite list.
At least with the old Tivo models (can't speak for other D* receivers), you could actually edit the 'channels I receive'. That way, you could remove channels that you technically did receive but never watched, so they never showed up even if you weren't using a favorites list. Even though they're getting closer to actually populating the list correctly, I preferred the ability to edit myself as well. (no, I'm not trying to turn this into a Tivo vs D* receiver discussion - just stating a factEven when the channels you get list is properly populated based on your subscription, you'll still want to set up a custom guide to eliminate those channels that you may never watch. Like the shopping ones.![]()
At least with the old Tivo models (can't speak for other D* receivers), you could actually edit the 'channels I receive'. That way, you could remove channels that you technically did receive but never watched, so they never showed up even if you weren't using a favorites list. Even though they're getting closer to actually populating the list correctly, I preferred the ability to edit myself as well. (no, I'm not trying to turn this into a Tivo vs D* receiver discussion - just stating a fact)
Limited time offer
